Filler Plugs/How to lossen?
Herb
06-25-2004 07:22:27
Greetings!
There are two filler plugs on my David Brown (Oliver 500). Next to the gear shift lever and the range lever/transmission dip stick.
I purchased a manual for the Oliver 500... does not show a filler plug next to the range lever.
In fact, the manual has some misguided information.
Questions:
1) What is the purpose of the left filler plug?
2) How does one loosen the filler plugs? The plugs have a recessed "head?, shaped like a ?square".
Tried to use my socket wrench, but to no avail.
Kind regards,
Herb
"Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so." Douglas Adams
Mike (WA)
06-26-2004 08:12:29
 Re: Filler Plugs/How to lossen? in reply to Herb, 06-25-2004 07:22:27
Usually, the recessed square hole will be an even dimension, and you can get a short piece of key stock that will fit. I know for a fact that the rear axle key for a MM 4 Star fits the transmission fill plug of an IH 504 perfectly :o)
Hbee
06-28-2004 10:20:09
 Re: Re: Filler Plugs/How to lossen? in reply to Mike (WA), 06-26-2004 08:12:29
"Usually, the recessed square hole will be an even dimension, and you can get a short piece of key stock that will fit"
Tried the above procedure,prior to your post. no luck
thanks for the reply.
regards,
Herb
