40 tractor
Dave M
06-22-2004 18:01:16
I bought a 1952 40 Cockshutt back in the winter. I have been working on it off and on. I want to thank everyone who has given me good advice from this site. But (alway a but) I still can not get the tractor to run with out missing out. I have reworked the head, installed new points and plugs, plug wires, cleaned the carb ( do have a small tube that goes into the venturi that is cracked). It just will not run with out a miss. I would like to bring it to Bluffton to the show.
Any help???
Red
07-25-2004 01:22:31
 Re: 40 tractor in reply to Dave M, 06-22-2004 18:01:16
Dave M. did you happen to have seen an add for a Perkins-40D4 Golden Eagle on here for sale.Some fellow up in MN of Wis. had it listed with some serious motor workkdone to it.Thanks Red
Wade
06-22-2004 20:32:29
Did you try a replacement ignition coil?
Dave M
06-27-2004 13:35:57
 Re: Re: 40 tractor in reply to Wade, 06-22-2004 20:32:29
I intalled a new coil, did not help my problem, but it did give a spark that you do not want to get between, nice little kick.
Dave M
06-23-2004 12:07:04
No not yet, I will replace .. Thanks
Will you be at Bluffton show??
Wade
06-23-2004 16:29:34
 Re: Re: Re: 40 tractor in reply to Dave M, 06-23-2004 12:07:04
Dave M,
Unfortunately "no", I cannot make the Blufton show. I recently accepted a transfer to the Atlanta, GA area with work and that has significantly squelched my Cockshutt hobby. However, did get the opportunity to get the 50, Super, and 1755 out to put in hay two weeks back in southern Ohio - so at least I get to have some fun. Enjoy the show. Hope to be back in the loop in future years.
J. Schwiebert
06-23-2004 12:30:20
Have you used a vacuum gauge to help you trouble shoot the problem? We are getting an article ready for the Oliver newsletter on how to do this and if you want an advance copy and want to try it in case we have some"bugs" in the article let me know. However I need your feedback good or bad.
Dave M
06-23-2004 15:32:34
 Re: Re: Re: Re: 40 tractor in reply to J. Schwiebert, 06-23-2004 12:30:20
Sure, I would like to get the old fella running better. I would be glad to give feedback.
My e-mail is [email protected]
Thanks for you help
PHeisey-Harleysville,PA
06-24-2004 20:01:15
 Re: Re: Re: Re: Re: 40 tractor in reply to Dave M, 06-23-2004 15:32:34
Dave,
I have the distributor bushings on stock if you need them.
Phil Heisey 215-256-8651 FAX 215-256-1203
Canada Grant
06-24-2004 13:24:00
Look at distribtor shaft for wear , we had a 30 that was so worn you could open and close points by moving shaft back and forth. New bushings solved problem.
ShepFL - grins
06-25-2004 05:37:46
 Re: Re: Re: Re: Re: Re: 40 tractor in reply to Canada Grant, 06-24-2004 13:24:00
Hey CG!!
He walks, he talks, he posts. I lost your email addy, had some cool FL native pics to send ya.
Check out Stuck and Troubled "Deer(E)"
Hopy all is well.
