carbs
kevin m.
06-21-2004 19:34:27
I have A 77with the 363 carb and I was woundering if I put A carb off A 770 on it would I get more h.p.? Ihave the big sleeve kit,worked cam, and large valves?
thanks for any help or direction kevin
7
06-22-2004 19:07:09
 Re: carbs in reply to kevin m., 06-21-2004 19:34:27
it probably won't help much with h.p. but will help your engine run better.
Wes Dorhout
06-23-2004 01:54:04
 Re: Re: carbs in reply to 7, 06-22-2004 19:07:09
Replacing the carb. will help if you also replace the air cleaner and intake/exhaust manifold with 770 style.
