Oliver 550 Bearings
Kerry
06-21-2004 17:00:04
I'm looking for a source for Transmission Bearings (part # ES-5020) for an Oliver 550 ... and potentially other bearings as well.
I've not been able to find them in the "aftermarket" area, so HELP!
jeinsc
06-23-2004 06:21:32
 Re: Oliver 550 Bearings in reply to Kerry , 06-21-2004 17:00:04
I have been working on a S55 transmission. Called my local bearing house,thay could have
the 5 bearings and seals I needed next day. web site Ibearings.com jerry
Kerry
06-23-2004 16:45:59
 Re: Re: Oliver 550 Bearings in reply to jeinsc, 06-23-2004 06:21:32
Jerry, could you clarify that link? It's not working on my end ... thanks in advance!
jeinsc
06-24-2004 09:27:07
 Re: Re: Re: Oliver 550 Bearings in reply to Kerry , 06-23-2004 16:45:59
sorry Kerry my broblem try ibearing.com that worked
my end with yahoo netscape. I had to take the seals that only had 1E###, they measured them,
those 50 year old ball bearings may them look in
all the old books,they crossed them. Bearing Distributors seem to only be in NC&SC. Any bearing house should be able to help. JERRY
Geoffrey in KS
06-22-2004 17:24:27
Try the link below and find the store nearest you. They will be able to get just about any bearing for you. If your 550 parts book is like the one for my 88 it will have the manufacturers (Timken, Hyatt, etc) part number listed after the part description. Give them that and they should be able to match it.
Super 55
06-22-2004 21:28:49
 Re: Re: Oliver 550 Bearings in reply to Geoffrey in KS, 06-22-2004 17:24:27
If you find a new one at that link, let everyone know. They could sell a ton of them.
Kenny
06-22-2004 10:52:08
Try Shepard Equipment Co. Ridgeway MO 660-872-6316 They have been there for 50 + years. Got alot of old stock.
Jim Kline
06-22-2004 06:28:02
These bearings are obsolete and hard to find. I have some good used ones. If interested, call 937-981-3985.
Pete
06-22-2004 05:55:02
Try G & R Implement Co. in Durham, Kansas.
620/732-3245 or 732-2275
Super 55
06-21-2004 23:54:45
YOu have found the obsolete bearing. You will have to find used. Try Maibach's or O'Brien County. Others might have other leads. I was lucky to find some close by, and have a back up pair from O'Brien County.
