Generator Pully on 77 Row Crop
Russ Vetter
06-21-2004 16:12:03
I have an Oliver 77 Row Crop and I just replaced the belt on the generator. The cover now comes in contact with the fan of the generator; it is really close and wouldn't take much to make it miss. Also the amp is close to 20 when running at high rpm and normal when at low rpm. I was wondering if the pully was to small. This is a replacement generator and was wondering if the pully was the wrong size.
Geoffrey in KS
06-23-2004 11:16:50
 Re: Generator Pully on 77 Row Crop in reply to Russ Vetter, 06-21-2004 16:12:03
It sounds to me like you have the wrong pulley. I would assume that it should be like the one on an 88. It is cast, has the Oliver part number cast into it and is about 3/4 the diameter of the generator. However, it may not fit the shaft on your replacement generator. Hope this helps.
