Cletrac HG info
Jason
06-21-2004 15:57:39
I'm finally getting my Cletrac HG together after it was apart for 5 years. What i'm not sure about is this tube i think is for the wires to go through and how to place it, i was told by some people that they don't think this is original, and it should just have a loom around the wires instead.
RAB
06-21-2004 23:27:45
 Re: Cletrac HG info in reply to Jason, 06-21-2004 15:57:39
You are referring to the protector for the HT leads which is bolted on with head bolt(s)? The exit holes need to line up for the leads to reach the plugs without excessive bending and for the tube to avoid the manifold. As long as it is complete, it is difficult to get it wrong without being obvious.
Regards, RAB
Jason
06-22-2004 18:35:02
 Re: Re: Cletrac HG info in reply to RAB, 06-21-2004 23:27:45
Thanks for that, but with the tube length one of the ends on the U shape is longer than the other, which one goes on top where the manifold is?
RAB
06-22-2004 22:39:28
 Re: Re: Re: Cletrac HG info in reply to Jason, 06-22-2004 18:35:02
IF that is the part, the exit holes for the HT leads will be fairly adjacent to each of the plugs.
Regards, RAB
Ray
06-23-2004 06:23:08
 Re: Re: Re: Re: Cletrac HG info in reply to RAB, 06-22-2004 22:39:28
Jason,
There is a U-shaped tube that connects to the ware pump and goes around the oil filter and down to the bottom of the radiator. This is the only U-shaped tube on an HG.
Ray
06-23-2004 06:24:57
 Re: Re: Re: Re: Re: Cletrac HG info in reply to Ray, 06-23-2004 06:23:08
Sorry, that was supposed to say WATER pump, not WARE pump
