Need some info on Oliver
Dave
06-21-2004 13:31:39
I have a 84 year old neighbor that has a OC 3 crawler with a Herc. flat head four cly. He has replaced the rings and has asked me how he could go about replacing the valve guides. This old girl is a little before my time. I told him that I thought they just drove out, but I thought I would ask one of you kind folks just to be sure. Also any helpful advise on the best way to do that would be great. He has been a logger his whole life and at 84 he still cuts logs and uses the little crawler to skid them out. Thank You!
RAB
06-21-2004 14:00:58
 Re: Need some info on Oliver in reply to Dave , 06-21-2004 13:31:39
You will also likely need to recut the valve seats as the concentricity may have changed, and,of course, may need new valves to fit the new guides. Regards, RAB
Dave
06-22-2004 06:21:42
 Re: Re: Need some info on Oliver in reply to RAB, 06-21-2004 14:00:58
I understand that it is probably going to need new valves and I told him that, but do the valve guides, just drive out from the top, or is there a special way of getting them out. Dave
Ray
06-23-2004 08:30:52
 Re: Re: Re: Need some info on Oliver in reply to Dave, 06-22-2004 06:21:42
Dave, yes the valve guides are just pressed in. If you need info call me at 717-738 2573
Ray
