Clutch not disengaging
Dale in MN
06-21-2004 11:13:53
I have a 77 standard (1952 model) that I can't get the clutch to disengage. I started it yesterday and let the motor warm good, then shut it off, put it into reverse and started it. Backed it out of the shed and up onto a grade. Shut it off and put it into 5th gear and started it again with the starter and the grade.
I had it going in 5th, clutched it and hit the brakes. Someone on another discussion bd said that might work. It didn't. I later put it into 6th gear and tried the same thing. I could get the tractor to stop, but was pulling the motor hard. So put it back into the shed and shut it off.
When I push real hard on the clutch petal, it makes one heck of a racket, worse than a gear gringing noise.
I'll appreciate any suggestions from you Oliver folks. Thanks. Dale
Stu
06-21-2004 12:22:50
 Re: Clutch not disengaging in reply to Dale in MN, 06-21-2004 11:13:53
It sounds like you have a broken finger on the pressure plate or a bent clutch fork. I would slide the bellhousing back to give a visual inspection. It is also possible for the fingers on the plate to be out of adjustment. Hope this helps.
