Oliver 88 governors
Ray
06-16-2004 22:19:06
I can drive 1951 Oliver 88 gas tractor down hill and it speeds up to crazy rpm's. I go up hill and it slows way way down. I've been regulating with throttle but, I need some help in fixing governors. What do I need to look for and are parts available?
Thanks,
Ray
J. Schwiebert
06-17-2004 16:58:05
 Re: Oliver 88 governors in reply to Ray, 06-16-2004 22:19:06
Well the first thing I would do is inspect the linkage for wear. I would mark the holes if they are worn, then braze them shut and redrill them, I would also take the governor off and inspect the thrust bearing and the weight assembly. You will probably also need a new thrust washer which is located behind the governor gear, Make sure the weight retainer is also tight on the shaft. That is a place to start.
