550 diesel getting fuel in oil
JD dozer mike
06-15-2004 21:55:54
our 550 diesel is getting fuel in the oil pan. is this common problem for the 550 , im guesing that the fuel siphon pump diaphragm is leaking it into the block . or maybe the injection pump has a bad seal where it mounts into the timing trane. Any one else have this problem , and where can i get a rebuild kit for the syphon pump , it is just an "A-C" pump but NAPA says they cant get it.
Mike (WA)
06-17-2004 08:00:05
 Re: 550 diesel getting fuel in oil in reply to JD dozer mike, 06-15-2004 21:55:54
I had the same problem- I ended up getting a cover plate for the fuel pump mounting flange (from AGCO, I think), and got an electric fuel pump (universal type) from NAPA. Works fine.
