ARG....
Don-WI
06-09-2004 20:22:40
Now that the rain finally let up, I was using the 1855 in the feild and I blew a hydraulic line last night. The mosquitos were too much and it was too dark out so I went back out tonight. After taking off the platform over the pump to find the leak, I found it. I think it supplies the steering. It's about a ft. long hose w/ a peice of pipe crimped to it, about 8" then bent 90 and another 4". The steel line was rubbing on the hyd. filter bracket. Anyone ever have this happen? last time I ran the 1855 a terminal broke off the alternator, and I replaced that as well. Sunday I started cutting hay, and broke the pitman on our haybine. Now rain's in the forecast and we can't get it off.
Just ain't my year.....
Donovan from Wisconsin
Pete
06-10-2004 12:31:28
 Re: ARG.... in reply to Don-WI, 06-09-2004 20:22:40
It will be better tomorrow. Or the next day.. Or the next. Keep the faith. I was wanting to get hay cut this week. Weather man said 4 days hot and dry. Well got to field and swather broke on first round. Was upset cause it was going to take a couple days to get parts and repair. Next 2 days were cloudy with high humidity and rained the next 2. Would have had hay down and rained on if I hadn't broke. Someone was watching over me.
Spike
06-13-2004 06:41:30
 Re: Re: ARG.... in reply to Pete, 06-10-2004 12:31:28
If I was wrong as often as the weatherman I wouldn't be able to keep my day job!!!!!
Don-Wi
06-10-2004 18:54:10
Well, it wouldn't be so bad but I fixed it on Monday and cut about 10-13 acress... Should've knew better... O well
