Super 55 D
Skip
06-08-2004 11:08:36
Help My super 55 diesel is leaking fuel/oil out the bottom of the inspection plate holes under clutch areas.I turned on the fuel and it poured out the bottom . I also was afraid to start it so added oil it also poured out.When i got the tractor the inspec. plates were missing, i made some up and put cotter pins in the center. It runs and starts ok ,but i have diluted motor oil as well, Any suggestions, its a rugged loader tractor with bucket ext. for snow no 3pt or pto ,I think it was orig. yellow but is oliver green now.It also has a locking brake problem and steers a bit hard even w/ new bushings.I wanted to sell it but can't in this condition. It has bosch fuel injection pump. Any ideas would be great. It does not get daily use and is 170 mi from me. Thanks for all replies.
Larry from MD
06-08-2004 16:41:57
 Re: Super 55 D in reply to Skip, 06-08-2004 11:08:36
Well the primary fuel pump diapham could be shot lettin diesel into the crankcase.the oring in the main pump could be bad letting in fuel.Unbolt the primary pump and pull a small gap from the block.Then turn on the fuel if it runs out there thats whats bad.If it don't then its the other.
