Oliver 550 engine block
James Alexander
06-07-2004 16:28:37
Just found an engine block which appears to be identical to my 550D block,P/N 1LB-100. Except the P/N(s) are 180220L/159002A. The four digits of the bottom line are 6155. Also has a hump on the main bearing caps which my block does not have. Can't find any other differences. Anybody have a guess if it will work or what it came from? My tractor is a '59 model-I don't know if they changed the block P/N at some point in the production of these tractors. Thanks!
J. Schwiebert
06-07-2004 19:01:21
 Re: Oliver 550 engine block in reply to James Alexander, 06-07-2004 16:28:37
You have the early 144 cubic inch engine. The block you found is a later block for a 155 cubic inch engine. I tcan be used to replace your block if that is your question
