Did he screw up the gears???
Farmallkid
06-05-2004 10:02:40
Hi, My friend bought a 660 oliver, nice tractor, runs great, and the tin is straight. They had a big old tractor, it is a ford 9600, Thats a big tractor. the engine seized up one day, so he thought he would tow it with the 660 to the neighbours, they bought it. He was pulling it in 4th gear. Now there is some banging in the back end. what did he wreck in the back end? I'm into the farmalls, dont know much about olivers, dont know much about the back ends of tractors yet. thanks for any help.
Larry from MD
06-06-2004 17:41:42
 Re: Did he screw up the gears??? in reply to Farmallkid, 06-05-2004 10:02:40
I would look for stuff on the outside first.Loose or broken axel u bolts,loose lug nuts or wheel bolts.Look at the wheel weights and see if they move or flop on every revolution.I would look at the brakes next,last thing would be to go digging around in the inside.
J. Schwiebert
06-06-2004 16:50:52
Well, how often do you here this noise? Better yet, remove the PTO, then the hydraulic unit and the bull gear cover and everything will be in plain site. On Randy's comment. You will also find some older ones tha have bolted ring and pinon gears. We also had a few chipped L-606 gears, but I doubt that is your problem.
Randy-IA
06-06-2004 11:06:27
Hi , I'm new to tractors in general but I just got the first edition of Oliver Heritage and in this issue they feature the 660 . If you can get a copy the article on 660's might give you some answers . The ring gear on early 660's was riveted on , in '61 starting with serial # 114 767 they were "bolted" on . I hope it's not too bad . Good Luck -Randy-IA
