Semi-fluid grease??
Dennis(WA)
06-21-1999 09:37:21
My Oliver 77 manual says use semi-fluid grease in the front wheel hubs, 1/2 pint. Does anyone know where to buy this "grease" and a brand name? Manual also says it must be water resistant and able to flow at zero degrees.
Billy
07-07-1999 20:38:10
 Re: Semi-fluid grease?? in reply to Dennis(WA), 06-21-1999 09:37:21
I have the original owners manual for my 1949 77 row crop. Manual says use motor oil in hubs. The original seals on mine had gone bad and being of odd design, I re-engineered modern seals to fit the hubs and had a collar machined to fit the spindle where the new seal rides. I packed bearings with ordinary wheel bearing grease. Works fine. Hope this helps
steve
06-24-1999 16:22:50
could it be an open gear grease, that comes in a aresaol can??
randy
06-22-1999 05:21:24
semi-fluid grease sounds like a contradiction of terms to me. the grease i use in my grease gun for is nowhere near semi-fluid. what exactly does semi-fluid mean??
maybe they're talking about a transmission-weight grease. 80-140W.
Dennis(WA)
06-22-1999 08:04:37
 Re: Re: Semi-fluid grease?? in reply to randy, 06-22-1999 05:21:24
No they are not talking about 140W gear oil. They say us 140W in the gearcase. They are specific in stating "semi-fluid grease". It must be a lot heavier and thicker than 140W and still have flowing capabilities.
Bill
06-22-1999 11:22:00
 Re: Re: Re: Semi-fluid grease?? in reply to Dennis(WA), 06-22-1999 08:04:37
This doesn't answer your question but this is what works excellent for me. I fill the hub 1/4 full of wheel bearing grease (I use Quaker State) and fill the cap with STP OIL TREATMENT. When the grease and the STP mix it turns semi-fluid. Works great on trailer hubs. Keeps the grease from drying out.
Art
06-22-1999 20:29:22
 Re: Re: Re: Re: Semi-fluid grease?? in reply to Bill , 06-22-1999 11:22:00
I would say it is a grease like what is/was used in Multi-Luber systems.
