Oliver 2050 power problem
Jim C
06-04-2004 20:28:56
for some reason i couldnt post a followup to other messages..
Thanks for the replies...is the 478 hercules the perkins engine? i dont think there is a fuel flow problem, but will pull filters tomorrow to verify. no difference when operating with linkage off. Whats the procedure for adjusting the timing? Sounds like an alternative may be switching the pump, where would a model 100 be available? idea of Cost? and what do you think the value of the tractor might be..other than this issue, it is in very good shape, even the fender tanks and paint is not bad. One more ?..on the dash to the right of the key, there is a pushbutton. Turning the key appears to activate the preheat, what specifically does the PB activate? Thanks!
