Oliver 550 Gas tranny
Allen
06-04-2004 12:27:32
Just bought a 550 broke down in the field. The transmission is locked up and the shift lever will not budge. I took the two screws loose on the shft lever but see nothing I can accompllsh. the tech manual shows how to take the top plate off the transmission which I will attempt next. Any suggestions from anyone over what I may be looking for? Your help is greatly appreciated.
jake
06-04-2004 18:10:51
 Re: Oliver 550 Gas tranny in reply to Allen, 06-04-2004 12:27:32
Take the shift lever out looking down there will be three rods take a long screwdriver and line up all the machined grooves. You are locked between 2 gear positions due to sloppy shifting, make sure the lo or high is is in proper position and the gear is shifted in a straight line. The tractor might have to be rocked to release pressure.
Allen
06-07-2004 05:16:40
 Re: Re: Oliver 550 Gas tranny in reply to jake, 06-04-2004 18:10:51
Thank you Jake, I will try this. Regards, Allen
