Oliver 88 getting hot
Scott
06-03-2004 17:35:09
After 20 -30 minutes pulling a 10 ft. disc, tractor overheats. Tightened fan pulley. No change. Any thoughts? Thank you, Scott
Farmall Daddy
06-03-2004 18:25:55
 Re: Oliver 88 getting hot in reply to Scott, 06-03-2004 17:35:09
Sounds to me like it might be a thermostat. By replacing it, that should keep it cool if that is the problem. I would start there, and if it continues to run hot, better take the radiator in and have it cleaned out. I pull a 14ft disk with my 88, and it will get to the run area, and stay there. Do you know if the motor has an oversize kit in it? Good luck!!
