Electrolisis block repairs?
Adam
06-01-2004 19:50:46
I have a 880 diesel I'm rebuilding. I'm scraping The original engine block due to electrolisis damage. I found another block but again there is some pitting around where the upper O-ring sets against but is ok for the lower o-ring. Has anyone done somthing to doctor up the pits? expoxy? I have had a 1755 block repaired by a shop who resleeved the lower block which is the way to go. However the equipment to do such repairs has traded hands and is now beyond my fund availability. I'm sure it will seal for now but I plan on activly using this tractor for along time and need to be sure it won't get water in it. Any suggestions? A sealer of some sort? Thanks.
Gary H.
06-03-2004 19:03:37
 Re: Electrolisis block repairs? in reply to Adam , 06-01-2004 19:50:46
Where I work we have also had a third o-ring groove cut in the sleeve between the 2 existing grooves. Its worked good for us.
Danny Tabor
06-02-2004 09:24:35
J.B. Weld should do the trick for you. I've repaired many blocks w/ the stuff. W/ JB Weld only use what you need and try to get it in shape while its some what soft. You can still sand it after it hardens but the less time you spend sanding. The better!
