550 Diesel valve adjustment ??
JD dozer mike
05-30-2004 17:38:59
Anybody have specs on Oliver 550 Diesel valve adjustment ? Need to know tappet clearence and sequence. email me if you can , with the subject heading "oliver" . Thanks so much Mike
Nick
05-30-2004 21:00:51
 Re: 550 Diesel valve adjustment ?? in reply to JD dozer mike, 05-30-2004 17:38:59
The valves on that diesel engine are set cold, or room temperature, to .009"-.011" for the intake and .019"-.021" for the exhaust valve. The first valve is an exhaust valve. The next two are intakes, the next two exhaust, the next two are intakes and the last one is an exhaust. Start from the front of the engine, turn clockwise until the intake and exhaust have closed on the first cylinder and turn an additional 145 degrees. Set the ones on the first cylinder. On cylinder two, repeat the same as number one. Continue till all cylinders are set.
