Super 55 PTO set screw
Bill
05-29-2004 17:41:22
There is a set screw in the PTO clutch. Is there a hole or notch in the shaft for this screw?
The screw is missing. Can any set screw be used?
RockinB
05-30-2004 05:09:51
 Re: Super 55 PTO set screw in reply to Bill, 05-29-2004 17:41:22
There are two set screws required,one on top of the other. The second one being staked so as not to work loose.
Bill
05-31-2004 14:02:35
 Re: Re: Super 55 PTO set screw in reply to RockinB, 05-30-2004 05:09:51
Thanks
jake
06-01-2004 12:49:08
 Re: Re: Re: Super 55 PTO set screw in reply to Bill, 05-31-2004 14:02:35
The pto shaft splines have a machined pocket for the allen screw which has tip machined to fit. The early 55's had one 3/8x 3/4, later models and update has 2 3/8 x 1/2 and 3/8 x 1/4. the position of the shaft pocket can be determined by the pto rear hub holes being verticle [might be 180 out just turn] the pocket can be felt using a punch. Gool luck
