OC-6 Leak ?
John
05-27-2004 10:29:01
I am looking at an OC-6 which seems to have water in the crankcase and somehow is leaking the mixture of oil and water somewhere at the rear of the motor. Is it possible for the crank seal to be bad and could this be where the leak is. Real hard to look at the back but I see no leaks around the head. Since the tractor does not look like it breaks apart, is the proper proceedure to change the seal to pull the engine ? Also is it more likely the head gasket is bad or should I expect the worst ?
