front oil seal oliver 770 gas
Mr Bill
05-25-2004 11:03:24
Can somebody tell me how to change the front oil seal on a 770 gas engine behind the main crank pulley? Any input would be appreciated. Thank you for any answers. A friends tractor and no manual.
Bob
05-25-2004 22:13:19
 Re: front oil seal oliver 770 gas in reply to Mr Bill No. Mn., 05-25-2004 11:03:24
you gotta pull the rad off, take fan, water pump, generator off, governor housing and front pulley. Will need a puller likely for the pulley.Than remove the front timing cover and your there. Make sure the inside of the timing cover isent worn excessivly were the oil seal seats against it. If its worn almost through, a new seal likely wont seal for you. If its wore bad, you can either find another better one(timing cover) or have a machine shop built the old one back up.Sometimes if the cover is only wore through half way or so, i get a thin washer the right size to fit over crank and notch out the keyway. Put this washer behind the seal and it will take up whats gone on the cover face.Good idea to soak the new seal in a pail of oil overnight before you install it to soften it up. Or if your in a hurry, 10 minutes under the boiling hot water tap will work too. Also make sure while your working on the seal with the timing cover off, that the cam spring and block dont pop out on you. If it falls out and isent noticed, you will break your cam when you start her up.Also check your thrust washer on the back of the govenor gear. They are usually wore bad or gone. Good time to put a new one of them in.
Mr Bill No. Mn.
05-26-2004 08:26:35
 Re: Re: front oil seal oliver 770 gas in reply to Bob, 05-25-2004 22:13:19
Thank you for the info Bob. Now I know what I have to look forward to. Now He has to find a sorce for gaskets and a seal as we don`t have anyone who sells olle parts around here.
