Rear hub 770
steve
06-19-1999 03:50:32
i think i have worked on this tractor as much as i have worked it, and only had it a few weeks, but i guess thats expexted. right now i need info on rear hub. The key sheared off, pretty sure it had been sheared before, the shoulders of the keyway are worn pretty bad, and the tappered axle is worn, the axle nut doesnt bottom out on the hub when the hub is slid all the way on, there is alot of slop in the hub, 1/4 to 1/2 an inch in and out. How do i determin if its the axle or the hub that is really worn? Any ideas on a price and where to get an axle or hub, or if there is any way to fix/shim the assembly? thanks for any info.
larry h
06-20-1999 06:43:24
 Re: rear hub 770 in reply to steve, 06-19-1999 03:50:32
we have the hub for 25.00 plus shipping the hub is softer than the axle so i think that is where you will find your problem
