Cockshutt engine R R
Tony
05-24-2004 13:32:51
I am exchanging engines in an old Cockshutt tractor for a friend. I can not find an ID plate on the tractor, but I did find a part that appeared to be replaced with a salvage yard part that was marked Cockshutt 540. I want to know the proper proceedure for removing the transmission input shaft so that I can lift the engine out of the frame.
kr
05-24-2004 14:40:10
 Re: Cockshutt engine R R in reply to Tony, 05-24-2004 13:32:51
If it is really a Cockshutt 540 it has a 162 cu.in
Continental flat head Eng with the dist in the middle of the head and as far as I know the Eng.can be slipped out of the input shaft by moving the eng forward.
Tony
05-24-2004 16:37:58
 Re: Re: Cockshutt engine R R in reply to kr, 05-24-2004 14:40:10
The tractor does have the flat head Continental engine with the distributor in the middle of the head. Thanks for the information. It just doesn't look like you can move the engine forward far enough.
kr
05-24-2004 20:34:14
 Re: Re: Re: Cockshutt engine R R in reply to Tony, 05-24-2004 16:37:58
You should be able to raise front of eng to clear
frame and pull engine.Are you going to use governor from old eng,I have a friend needing the
shaft from governor,and where are located?
Tony
05-25-2004 05:51:31
 Re: Re: Re: Re: Cockshutt engine R R in reply to kr, 05-24-2004 20:34:14
kr,
The engine that we are putting in the tractor was originally in a forklift and does not have a governor so we are going to use the original governor on the engine that we are installing.
