oliver 2050 / 2150
jim_ball
05-24-2004 06:08:25
was oliver 2050 / 2150 availible with 540 / 1000 pto ?
MikeO
05-24-2004 06:21:31
 Re: oliver 2050 / 2150 in reply to jim_ball, 05-24-2004 06:08:25
Yes, we have one. Check to see if yours has a shifting rail at the bottom right side of the unit. The rail should be locked by a 3/8's bolt sticking out of the bottom.
Shep Va
05-24-2004 10:29:27
 Re: Re: oliver 2050 / 2150 in reply to MikeO, 05-24-2004 06:21:31
I was pretty sure that all the standard 2050 and 2150 tractors had the dual speed PTO, but I could be wrong. Ours has the dual speed. Now if you get a wheatland tractor it probably will not have a PTO at all.
Check for the shift rail and that should tell you.
