Pump for Cockshutt Oliver 1855 (yr 1976)
L. Laframboise
05-24-2004 05:42:45
I am trying to locate a part fo a Cockshutt Oliver 1855 tractor (yr approx 1976). This is a small pump on the hydraulic system that lubricates the transmission. The pump is located in the front of the tractor (left hand side when sitting on the trator). It has three connections in Tee, one goes to cool the radiator. The pump turns on a pulley, the same one that the water pump.(Wakacha motor). If you can help me locate this part, much appreciated.
Thanks
Wes Dorhout
05-24-2004 11:10:11
 Re: Pump for Cockshutt Oliver 1855 (yr 1976) in reply to L. Laframboise, 05-24-2004 05:42:45
E-mail me or call 712-324-2760 I have a used one.
MikeO
05-24-2004 06:11:54
The pump you are referring to acts as a cooling pump for the hydraulic system, not for the trany. I have puchased two of these, one an after market unit from an Oliver used parts dealer and one from another farmer used. They shouldn't be that hard to find.
