tricycle front end 1650-1950
Jon
05-24-2004 04:03:53
I am looking for a tricycle front end for my 1850. Will any of the 50 series narrow front ends work and fit right under my 1850? Thanks
Rex
05-24-2004 20:52:04
 Re: tricycle front end 1650-1950 in reply to Jon, 05-24-2004 04:03:53
I have a narrow front for an 1850, no hubs, otherwise fine. 319-240-2852. Iowa
Shep Va
05-24-2004 10:33:48
No, I dont think so. The 16xx tractors have a smaller spindle and bearing system then the larger tractors. I am very certin you will need a front end from a 17xx or larger tractor to make it work. I think the front ends will interchange adn there is no physical difference in the front end, but you will have smaller spindles and bearings and hubs, and with the extra weight of the 1850 you will likely have problems with the smaller front end.
Also the 00 and 55 series tricycle front ends "should" work for your application if you get the bigger ones.
Good luck
Eugene SWIA
05-24-2004 08:53:51
I have one from a 1655 with hubs. The pedestal bearings are bad. I would sell either way bearings and seals repaired. Hub bearings repacked w/new seals or as is. Gene
