Horsepower (Brad?)
Oliver S-77 Pul
05-23-2004 17:27:56
We have an Oliver S-77 that we pull locally, the engine has stock stroke, 3-3/4" bore, head milled .060" and homegrown port job, cam ground, intake with 1-1/4" ports, exhaust with 1-1/4" ports, big Zenith carb, Ignition at 25 BTDC, RPM @ 1900 and according to the dyno it makes about 65 HP @ 540 PTO.
Now the questions, is this HP realistic, it seems high to me. And second question if we are really making 70 HP, why do we seem to be out powered by other 77's, WD-45's and Super H's?
Alan
05-26-2004 03:39:14
 Re: Horsepower (Brad?) in reply to Oliver S-77 Puller, 05-23-2004 17:27:56
I have built many racing engines and found that a homegrown port job can hurt you more than help you. I would recommend taking your head to someone with a flow bench and have them check it out. (could make a heck of a difference. Alan
Brad
05-24-2004 15:07:41
Yes, that is a realistic horsepower for that combination. It's hard telling why your getting beat by the other guys. the camshaft you have may not produce the torque the other guys have. or they may just have more done to their engines
kevin m.
05-24-2004 16:43:52
 Re: Re: Horsepower (Brad?) in reply to Brad, 05-24-2004 15:07:41
I just checked my compression on my '49 77 and it was from 150 to 155 psi.I did the same with my engine, big valves in the head execpt my manifolds and carb is just rebuilt and polished. The only tractor I can out pull an H. I hope to do beter this year my first pull is this weekend her in western Wis. I can't wait.
Paul, In Western WI
05-24-2004 17:27:23
 Re: Re: Re: Horsepower (Brad?) in reply to kevin m., 05-24-2004 16:43:52
Where is the pull at in Western WI ? I live near Bladwin, WI
kevin m.
05-24-2004 23:31:41
 Re: Re: Re: Re: Horsepower (Brad?) in reply to Paul, In Western WI, 05-24-2004 17:27:23
IT IS IN RIDGLAND ON SUNDAY. I THINK IT IS 20-25$ PER HOOK. THE AD SAID " RUN WHATCHA BRUNG AN HOPE YOU BRUNG ENOUGH" 4000LB-5000LB-6000LB.DON'T HAVE THE PAPER IN FROUNT OF ME BUT I THINK THE INFO. IS CORRECT.MABE I'LL SEE YOU OUT THERE? I HAVE THE ONE WHEEL WONDERER(NO PAINT YET STILL WORKING ON THE BALANCE).
