Oil types
Steve O.
05-20-2004 06:33:10
I have a White tractor. What oil type & grade do I put in the Main Frame gear case. Also Hydraulic oil what type! can I use AW46.
Shep Va
05-21-2004 09:11:59
 Re: Oil types in reply to Steve O., 05-20-2004 06:33:10
I have always used Shell oil in bulk at my shop and use it in all the tractors, mostly agco machines and a few IH. I run Rotella 15-40 in the engines, 80-90 gear oil in the transmissions and rears, ATF in the three speed, and Donax TD hydraulic oil in the hydraulic and steering systems. I really like the Shell oil products and have gotten along well with them. I have been doing this for over 10 years and have never lost a pump or engine from oil failure. I did lose a hydraulic pump due to a hose failure once, but that was not the fluid.
I am not sure what your AW46 oil is, but you should be using a premium clear/brown hyraulic oil in the system and keep the filters clean.
Good luck
