Bull Gear Driveshaft Needed for a 1964 Oliver 550
Kerry Brunner
05-19-2004 19:47:52
The story continues. After pulling the top off the transmission, we found that I need the righthand "bull gear drive shaft" for my 1964 Oliver 550. The gear that's on the shaft is chipped ... Suggestions, Please??
Help!
Super 55
05-21-2004 21:44:03
 Re: Bull Gear Driveshaft Needed for a 1964 Oliver in reply to Kerry Brunner, 05-19-2004 19:47:52
Kerry,When you replace the pinion, there is a thrust bearing that may need checking, and you will need to set the endplay and backlash.
Pete
05-20-2004 11:00:33
I take it that you are referring to the "differental bull pinion" - that is the short shaft that has the gear on one end and splines that carry the brakes on the other.
email me I think that I can help you out.
pete
J. Schwiebert
05-20-2004 15:12:21
 Re: Re: Bull Gear Driveshaft Needed for a 1964 Ol in reply to Pete, 05-20-2004 11:00:33
How bad is it chipped? If just one side of the tooth, We used to reverse a lot of them, that way the chipped side is only there when the tractor is driven in reverse.
Kerry Brunner
05-20-2004 20:33:26
 Re: Re: Re: Bull Gear Driveshaft Needed for a 196 in reply to J. Schwiebert, 05-20-2004 15:12:21
Hello, the gear is pretty well chipped in at least one spot and minor chips in other parts. The actual part number is ES-643.
Kerry Brunner
05-20-2004 13:12:36
Pete, I believe that's it. It's the gear (and shaft?? ~ can't tell) that drives the large bull gear on the rear axle. What are you asking for a righthand one with shipping to Wisconsin?
Kerry at [email protected]
PS: couldn't figure out what your email address was!
