Oliver 550 gear shift boot question
Joe
05-18-2004 13:17:00
I recently purchased a new rubber boot to go on my gear shifter for my 550. The problem is, how do I get it on? The obvious solution would appear to be to remove the gear shifter knob, but I have tried to turn it and it is not budging. Any suggestions from those of you who have been there before would be appreciated.
Thanks
ron
05-20-2004 07:58:37
 Re: Oliver 550 gear shift boot question in reply to Joe, 05-18-2004 13:17:00
i don't have a 550, but on my 770's to remove the knob, i wrap it with 6-8 wraps of heavy 1 1/2 electrical tape, then 1 layer of red shop rag, then very carefully turn COUNTER CLOCKWISE with a channel lock pliers. they come right off, and the grippers on the pliers don't chip the knob. good luck ron
JD in da UP
05-20-2004 04:45:31
without wandering over to the garage to check, I'd guess like most shift knobs that are threaded on, there is a locknut that needs to be backed off a little to get the knob loosened. if it's pressed on, start tapping gently. This isn't much help, just cause I'm too lazy to walk out to the garage.
Good luck
Joe
05-20-2004 10:44:28
 Re: Re: Oliver 550 gear shift boot question in reply to JD in da UP, 05-20-2004 04:45:31
Thanks for the replies and the help. I will now see if I can get the stubborn thing off!
jim young
08-31-2004 19:06:21
 Re: Re: Re: Oliver 550 gear shift boot question in reply to Joe, 05-20-2004 10:44:28
My 1958 550 does not have a shift lever knob.. . where can I get one? It does, however, have a Cone Automatic Machine backhoe mounted on it and a dozer-type front blade.
