880 hyd pump seals?
Jim Meade
05-17-2004 19:01:40
The Oliver shop manual and the I&T manual show two seals on each side of the shaft. The lip of the inside seal faces the bearing to hold in hydraulic fluid and the lip of the outside seal faces out to keep transmission fluid out of the pump.
An old Oliver mechanic tells me to put all the seals facing in to hold hydraulic fluid, as transmission oil (80/90) is unlikely to be a threat to getting into the pump.
Any experience, thoughts or comments on this?
Bob
05-17-2004 19:56:22
 Re: 880 hyd pump seals? in reply to Jim Meade, 05-17-2004 19:01:40
Absolutely, put all four seals in facing toward pump to hold oil in pump. Thats were all the pressure is, not in the rear end.
