Super 88 Diesel runs, Thanks Brad
Lynn
05-16-2004 21:39:17
I ended up getting a thicker head gasket to make the compression 18 to 1. I know that you dont agree with that but it seems to run extremely well. I am amazed at the responsive governor and the power it seems to have. I did have one problemm, I had 110 lbs of oil pressure at startup. I ended up taking the pressure regulating valve and spring out and then had 55 lbs at high idle. Thanks again for your help and you will probably hear from me again. I should probably drop the pan and turn the regulating valve back out on the oil pump so that the system is back to the way it was. With the spurt holes being welded shut, it really takes the pressure up.
Brad
05-17-2004 14:47:31
 Re: Super 88 Diesel runs, Thanks Brad in reply to Lynn, 05-16-2004 21:39:17
Good to hear you got it running, hope to hear how it does
