Oliver 700 questions again
Rich Iowa
05-13-2004 05:34:08
Thank you Ron and Scott for answering my earlier post. Few more quest. how heavy is this tractor, would a 1978 F150 be able to pull it, is it easy on gas, are the hydraulics single or double acting or is there a switch to go from one to the other, seeing how this tractor I'm looking at doesn't have the 3pt., were there cultivators availiable for it and are they still around, and fit on a wide front tractor. All the equip. I have are pull types except the front mounted cultivator that fits Farmall Hs and M. Might keep the H for cultivating and using the sickle mower, plus the 770 has a sickle mower. Thanks again for any and all info. Rich in Iowa
j meyer
05-13-2004 10:15:07
 Re: Oliver 700 questions again in reply to Rich Iowa, 05-13-2004 05:34:08
Your '78 Ford should handle a 770(I'm assuming thats what you mean) just fine. I had a '79 Ford, and that could do alot more work then many of the newer half-ton pick-ups. I now have a Heavy duty '95 Ford F-150 with a 351, and that still dont compare to that old '79.
