880 Brakes
Foxtail
05-12-2004 18:51:31
Put new disks in the brakes and replaced the pinion shaft oilseals at the same time, but I still get oil in the brake housing and on the disks. The shafts are dry do I don't think the seals are leaking. It almost looks like the oil may come in around the studs that hold the brake housing to the transmission case. Any thoughts or cures would be appreciated.
Chuck
05-13-2004 18:48:24
 Re: 880 Brakes in reply to Foxtail, 05-12-2004 18:51:31
A little pipe dope or pipe stick on the threads of the studs also works well. Good luck.
RAB
05-12-2004 22:57:26
Loctite.
Regards, RAB
