Super 99 GM shift pattern
Shawn
05-06-2004 22:15:21
We have a Super 99 GM (1957 I think} that has the single gear shift. Do they have the same shift pattern as an 88 or 77? If not what is the pattern. Thanks
GENE IN VA.
05-11-2004 07:45:10
 Re: Super 99 GM shift pattern in reply to Shawn, 05-06-2004 22:15:21
When I posted the reply to your question it moved the numbers. just shift the numbers back over in line and that is the pattern.
GENE IN VA.
05-11-2004 07:39:05
The shift pattern is not the same as the 77 and 88. The pattern is basicaly flip flopped. Here is the pattern on my 1956 model. High range 6 -- R | 3 -- 4 | | Low range 5 -- R | 1 -- 2
Shawn
05-12-2004 22:00:15
 Re: Re: Super 99 GM shift pattern in reply to GENE IN VA., 05-11-2004 07:39:05
Thank you for the information.
