Over/Under problem????
Joe
05-06-2004 18:30:39
I'm not sure what/where the problem might be. I took my 1755 diesel out tonight and could only get 8mph in 6th over, throttle wide open. I can feel the shifts between Under/direct/and Over. I need to change the over/under fluid and filter, the oil level is ok..but I don't know how long it's been since it's been changed or the filter... Could the final drive filter be a problem? Thanks!
j meyer
05-06-2004 19:24:48
 Re: Over/Under problem???? in reply to Joe, 05-06-2004 18:30:39
could the shift forks (lacking correct term here, I think!) be broken so your really in the low side side of the transmission???? Seems to me 4th is in the same spot as 6th on the low side, and 8mph would kinda jive with this thought of being in 4th..... .hmm..... others should weigh in on this one:)
Joe
05-07-2004 14:48:32
 Re: Re: Over/Under problem???? in reply to j meyer, 05-06-2004 19:24:48
I checked the main clutch, higher gears with the brakes locked it will stall the tractor. Lower gears it wants to push past the brakes...
j meyer
05-07-2004 18:07:13
 Re: Re: Re: Over/Under problem???? in reply to Joe, 05-07-2004 14:48:32
The reason I had that idea is because when I worked at a different implement, we got in a 1755 that wouldnt shift into a range. I got to drive it, but not work on it, and I remember that it went into the high and low sides on the pattern, but one side didnt work. Just a thought here....
