Engine Oil
Moe
05-06-2004 14:38:57
Need some advice. Can I put 20 WT. Castrol Diesall--Heavy Duty in my Super 66 without encountering any problems? Thanks
J.
05-08-2004 09:16:47
 Re: Engine Oil in reply to Moe, 05-06-2004 14:38:57
Is your Super 66 a gas or a diesel?
Kruse
05-06-2004 15:33:39
Sure. Won't hurt it a bit. Unless you are getting the stuff for free, my advice is that multi-vis oil is better than the straight-weight stuff.
15W-40, is a good all-around weight.
There are exceptions to using detergent oil, however.
If this tractor has never used detergent oil before, and it has many hard hours and the crankcase is full of sludge, you might avoid using a detergent oil until after an overhaul.
The sudden cleaning of a detergent oil can clog oil pumps or passages.
