tunning a tractor
peter
05-04-2004 17:00:51
what are the steps with a fresh motor to get optimum performance? idle low, rev up with no hesitations no stalling at idle ? I have mostly 4 and 6 cylinder gas motors any advice appreciated Pete
RAB
05-05-2004 13:31:42
 Re: tunning a tractor in reply to peter, 05-04-2004 17:00:51
Pete,
Check out the ignition system first and adjust as necessary to proper specification. Then check out the governor for correct operation.
If these motors are old in the tooth, don't idle too low unless the oil pressure is more than adequate at tick-over. You will probably find the carbs all need some sort of compromise unless everything has been renewed. Generally, they used to be (well, our kero-burners were) set up to work at maximum power and often just turned down a little (weaker mixture) on the main jet for light work to prevent plug fouling. I have always found that a short pull on the choke wire, before pulling away, works wonders in just richening the mixture at that point and provoking the governor a little (again the kero burners are perhaps a little different to the gassers).
Also a slight change to the float-bowl level can be beneficial on occasions. Btw - all my Ollies are 4-pot motors
Hope this helps.
Regards, RAB
