PTO Stabilizer kit for a Super 55
Kristian Anders
05-04-2004 16:35:02
Does anybody know where I can find a PTO stabilizer kit for the 3 pt hitch on a Super 55?
I had a kit on a Ferguson I had at one time but the brackets wouldn't fit on the Super 55 due to the axle being larger.
Thanks.
Thomas
05-08-2004 18:57:43
 Re: PTO Stabilizer kit for a Super 55 in reply to Kristian Anderson, 05-04-2004 16:35:02
We went to farm and home and we could get all the parts seprat for a ford the ones that go to the toplink we got from somewhere else but they look the same the other ons there are two diferant ones for a ford and our 550 used the shorter ones witch was the cheper ones I couldent beleve it the toplink ones I havent used yet but the others work good
RockinB
05-04-2004 20:41:48
Are you sure you don't mean a 3pt. hitch stabilizer kit.Why would you want to stabilize the pto?
Kristian Anderson
05-04-2004 20:59:34
 Re: Re: PTO Stabilizer kit for a Super 55 in reply to RockinB, 05-04-2004 20:41:48
Oops!! , yes you're right. I am looking for a 3pt. hitch stabilizer.
JD in da UP
05-05-2004 04:53:01
 Re: Re: Re: PTO Stabilizer kit for a Super 55 in reply to Kristian Anderson, 05-04-2004 20:59:34
I would like a pto stabilizer for my super 55. Just think, it would never wear out and stay the same forever. I would install it right after I got everything working just right!
Good idea Kristian, too bad we can't have both kind of stabilizers.
RockinB
05-05-2004 04:50:24
I have the set up on a 550 that appears to be after market.I use the same arms as fit the Ford after I repositioned the pin on the axle plate.Those rods are available at Tractor Supply as are the pins.The axle housing mounting plate could be easily fabricated from angle iron.The distance from the center of pin to the center of pin on a piece of equipment has to be the same as the center to center of the holes in the lower 3pt arm and inline with the 3pt mounting bolt on the housing.
