gregPA
goatfarmer
05-04-2004 13:10:18
Sorry to take so long getting back to you.
I have some numbers:
Fertilizer driven: 10 tooth sprocket, 245554BA number is on it. Round shaft
Fertilizer driver: 2 sprockets one with 20 teeth, and one with 22 teeth. No numbers seen, (somewhat rusty). Hexagon Shaft
goatfarmer
gregPA
05-05-2004 06:13:09
 Re: gregPA in reply to goatfarmer, 05-04-2004 13:10:18
good morning, i figured everyone was busy right about now. i will have to count the teeth on the gear. my small bevel gear rides on a square shaft.both my driven gears were shot. i bored out the center of the gear and machined a tapered shaft for in the gear drilled it out and ground the socket inside for the drive pin. pressed it into the gear then brazed it. other side was split off so i just brazed that back together. we planted with it and it held up so far, but i'd like to find a good set of replacement gears if i can. they sure are a nice little planter. thanks for the response and i'll count those gear teeth and get back to you. greg
