Needed - Cletrac experts
DuaneMN
05-01-2004 20:33:49
Bought a Cletrac over the phone - was told it had a 4 cyl Perkins engine with a stuck injection pump - was delivered today - has a 6 cyl engine with a Rosa Master pump - says Oliver on the exhaust - ModelCO12 -60DL - anyone know what kind of engine it is??? Has a super super heavy loader on it and pad tracks. Any one know where I can get a service manual?? Where they all painted yellow - was told it is a 1954. Are there any injection pumps around and the rubber coupler that drives the pump. This will be a challange before this is done!!!!!
John keys
05-03-2004 11:47:26
 Re: Needed - Cletrac experts in reply to DuaneMN, 05-01-2004 20:33:49
I have a HG42 46GA852 has a 3cy. gas i beleve it is hercules engine.Also it has 3 speed tran. Can anyone tell me what yr. it is. Thank you John.
jdemaris
05-02-2004 19:38:42
I don't think there ever was a Cletrac OC-12. The Oliver OC-12 replaced the Cletrac BD and BG crawlers circa 1954. They had a Hercules DJXC or JLXD six-cylinder engine, 298 or 339 cubic inches and around 60 horsepower. You can get all the parts you want for the Roosamaster/Stanadyne injection pump.
W. Komprood
05-02-2004 21:36:46
 Re: Re: Needed - Cletrac experts in reply to jdemaris, 05-02-2004 19:38:42
I have a Oliver OC 4 I got the rusi-master pump rebuilt in Dubuque, Iowa at a place called Desiel Componet Service. There phone number is 800-708-2445. I don't remember the guys name but he was real nice to work with and was very resonable. He will get you fixed up so it will run if you are just refinishing this unit or fix it like new if you intend to use it everyday. Most places will only fix it to 100% specifications but he will get you going for a lot less. He is located on the corner of White St. and 14th St.
sibby(Aus)
05-02-2004 01:10:37
Were they a Hercules diesel?
Jethro
05-01-2004 22:16:08
More than likely it is a wakashawa engine, it is also a OC 6 which you can still get a manual for
oliver is it
05-02-2004 03:56:31
 Re: Re: Needed - Cletrac experts in reply to Jethro, 05-01-2004 22:16:08
check with LANDIS ZIMMERMAN 717 738 4379 he specializes in cletracts
Sherry
05-02-2004 05:57:01
 Re: Re: Re: Needed - Cletrac experts in reply to oliver is it , 05-02-2004 03:56:31
Zimmerman Oliver Cletrac's phone number is 717-783-
2573. They could answer any questions that you have. That machines sounds like a OC-126 to me. If it is, it has a Hercules 6-cyl. DJXC engine.
DuaneMN
05-02-2004 17:54:22
 Re: Re: Re: Re: Needed - Cletrac experts in reply to Sherry, 05-02-2004 05:57:01
Does anyone know where to find the model # ?? (of the engine) Don't have time to get all the grease off right now!!!
Hockey Man
05-06-2004 20:34:45
 Re: Re: Re: Re: Re: Needed - Cletrac experts in reply to DuaneMN, 05-02-2004 17:54:22
I have three OC - 12 's if you need parts.
Bob
05-02-2004 20:31:58
There should be an aluminum tag on the left side of the engine. This will give model serial number and valve clearance. If it is missing the model and serial number will be stamped on the top right hand corner of the block just below the head.
