Engaging Olive 500 PTO Grinds
Farmer Glen
05-01-2004 18:37:05
When I try to engage the PTO it grinds and will not go in gear.
If I engage the PTO when the engine is not running, the PTO works fine when the engine is started.
Is there more to engaging the PTO than just pulling out the lever or is something broken?
Thanks!
dick
05-03-2004 16:35:32
 Re: Engaging Olive 500 PTO Grinds in reply to Farmer Glen, 05-01-2004 18:37:05
i also have an oliver 500 and i believe the first year they were built did not have the double clutch the only way i have been able to make mine work is to shut off the tractor to engage the pto i have tried everything short of splitting the tractor to verify the double clutch thing...
RAB
05-01-2004 23:56:49
You need to use the clutch?
If, like most David Browns of that era , it will have a two-stage clutch.
Regards, RAB
Farmer Glen
05-03-2004 05:54:56
 Re: Re: Engaging Olive 500 PTO Grinds in reply to RAB, 05-01-2004 23:56:49
Thanks RAB,
I tried the clutch and felt the first position when the clutch is half way depressed, but, while trying to engage the PTO it still grinds and won't engage.
The PTO engage lever is just above the PTO shaft, and you pull it out to engage.
Am I missing something or is something broken?
evielboweviel
05-03-2004 14:47:13
 Re: Re: Re: Engaging Olive 500 PTO Grinds in reply to Farmer Glen, 05-03-2004 05:54:56
ok to engage the pto push the clutch all the way down. when you let the clutch up to the step postition the pto will operate but the tractor will not move. letting the clutch further up will set the tractor in motion. So if you are mowing and push the clutch down to the first stop the tractgor will stop and the mower will turn.
Good luck Ron
Farmer Glen
05-03-2004 19:26:01
 Re: Re: Re: Re: Engaging Olive 500 PTO Grinds in reply to evielboweviel, 05-03-2004 14:47:13
Thanks Dick and evielboweviel,
My Oliver 500 is a 1960.
I have tried engaging the pto while the engine is running with the clutch fully depressed and it just won't go. There is so much grinding and I have not tried to force it real hard.
Like Dick, if I engage the pto when the engine is off and then start the tractor the pto works.
Any other ideas?
Thanks!!
evielboweviel
05-04-2004 17:55:29
 Re: Re: Re: Re: Re: Engaging Olive 500 PTO Grinds in reply to Farmer Glen, 05-03-2004 19:26:01
ok I understand better now
Don't have a book on this or much experience on this model. I have been told the clutch relase fingers have to be adjusted just right. along with other adjustments. So only thing I know is to find a book or get a copy off of somebody and adjust it properly. You may have to split the tractor to get to the clutch to adjust it properly.
SORRY can't be of more help
Ron
Canada Grant
05-05-2004 16:39:07
 Re: Re: Re: Re: Re: Re: Engaging Olive 500 PTO Gri in reply to evielboweviel, 05-04-2004 17:55:29
Jump over to case board as 500 is david brown ask Elmer he will fix you up!
