Oliver 1850 Loader Tractor????
The Rodent
04-29-2004 19:29:29
I saw a real nice Oliver 1850 on e-bay, great condition. And I have a Western Dwarf loader that needs a tractor. Will this Oliver 1850 be a good loader tractor or should I just forget it??? Thanks For Any Help!!!!! !!!!! 1
Kelly MT
05-02-2004 21:38:58
 Re: Oliver 1850 Loader Tractor???? in reply to The Rodent , 04-29-2004 19:29:29
I have a 1850 MFWD with a JD loader on it. Like Sam M said in close quaters you need a smaller machine. I use mine to plow snow, handel 2000# fertilizer bags, dig manure, handel large round and square bales and lift implements on and off trucks and trailers. The beef in the 1850 is real nice. PK
Sam M
04-30-2004 07:35:04
In my opinion , it all depends on what you are looking for . This tractor is about 92 to 95 hp on the pto and heavy so , to me , it is larger than the type tractor on which most people put a loader . If you are needing the loader for close work say in a barn this tractor may not work . On the other hand , if you are out in the open and need a heavy , strong pulling tractor , this one would be good . It has the ability to be plumbed for a power beyond set up so you do not have to use your remotes for the loader (the loader will need its own valve though ) . If the 1850 you are looking at has the over under auxillary transmission ( three speed shifter) it would be really good with a loader since you could change three speeds without putting in the clutch . The transmission on my 1850 shifts really easily from foward speeds to reverse speeds and power steering is really good , both of which are important for loader work . I would only buy an 1850 for loader work if it is a wide front tractor . I have read on this web site about Olivers with a tricycle front ends and a loader turning over . Just my thoughts , other may feel differently .
