governer Qs
mike w
04-29-2004 07:54:03
i have an 880 that i pull 4000-6500, 3-5 gear. im only running around 2500 rpm, i would like to get that to 3000, will over riding the governer do that for me, and or will i turn more more..thanks
zig
05-03-2004 15:18:32
 Re: governer Qs in reply to mike w, 04-29-2004 07:54:03
Grind govenor weights down i am running 2800 rpm at440 CI it will be more responsive and you wont have to tighten up on your spring so much
Bob
04-29-2004 23:58:15
You should keep your governor operational for 3000 rpms.The newer style pierce laminated governor is the best. Start by removing the governor spring which is directly behind your air breather. Remove the stop blocks in the spring and put them back in having 3 coils inactive to the front side and 3 coils inactive to the rear of the tractor.You should than have 18 active coils between the two stops. Than start shorting your throttle rod(the one that runs up under the fuel tank)at the front(directly behind carb) till you reach 3000 rpms. Just keep turning the threaded block that attaches to the flat bar behind the carb counterclockwise till you have shortened it enough to reach your speed. You will maybe have to snip the end of the threaded rod off after your done, as it will want to hit the bracket which is bolted to your block when you idle you tractor right down.Than when your done with that, you will need to re-adjust your governor linkage.Turn the bumper screw on the governor housing right out and tighten. Than, with throttle at bottom of quadrant(full throttle) remove the governor to carb rod at govenor lever and with rod shoved toward back of tractor(carb wide open) you want the rod 1/8" in front of hole on govenor operating lever. I think factory setting is 1/16th, but you want more pressure for what your doin. Leave bumper screw right out, as surging is not a problem when your pulling.
RAB
04-29-2004 09:05:05
Don't rightly know the answer (but breathing might be a limiting value) and was just wonderin' - does it have cast iron or aluminium pistons?
Interested to know how many rpm's c.i. pistons will go to safely, before stretching some of these old spindly rods?
Regards, RAB
mike w
04-29-2004 10:25:03
 Re: Re: governer Qs in reply to RAB, 04-29-2004 09:05:05
alum pistons, the motor has been fully redone, 333ci somewhere around 115-125hp....i know guys that can turn 3000rpms with less work then i have done, dont no why mine wont, and i dont wont to ask my motor builder about doing away with the governer, i dont think he would like that idea...
