4-175 Hydralic HELP
EW
06-14-1999 09:39:18
Sometimes the hydralic system does not work on our 4-175. If it dont work when it is started, we have to shut it off and start it several times until it works. Seems to do it intermittantly, not every time, but only when cold. It affects the whole system. A serviceman from an AGCO dealer has been out twice and went through filters, pump,and had valves apart with no success. Has anyone had a similar problem? Thanks for any help.
Wrenchbender
06-14-1999 19:45:22
 Re: 4-175 Hydralic HELP in reply to EW, 06-14-1999 09:39:18
It sounds like your unloader valve is sticking. The unloader valve keeps the hyd. pump from building up pressure while you are starting the tractor. When the hyd. is working shut the tractor off and listen for a click from the control valve,that is the unloader valve opening up to release the pressure,you may need someone on the ground to listen for the click, it will happen a few seconds after you shut the tractor off and it may be hard to get out of the cab in time to hear it.Then when the hyd. is not working shut the tractor off and listen for the click,if you don't hear it,that means the unloader valve was not closed and that is why the pump did not build up pressure.
EW
06-15-1999 04:31:24
 Re: Re: 4-175 Hydralic HELP in reply to Wrenchbender, 06-14-1999 19:45:22
The valve under the hyd filter and hyd pump was torn down and a worn ball was replced. Is this the unloader valve? The dealer we are working with sold 1 2-155 over the years and nothing bigger, so they dont have much experience with this tractor. Thanks for the reply.
HYDRO
06-14-1999 13:55:19
sounds like the modulator spring in he elipdicator
valve is too weak. Try replacing it with a 2000
psi spring.
w.t.
06-14-1999 14:25:22
 Re: Re: 4-175 Hydralic HELP in reply to HYDRO, 06-14-1999 13:55:19
good thinking
HYDRO
06-14-1999 18:58:11
 Re: Re: Re: 4-175 Hydralic HELP in reply to w.t., 06-14-1999 14:25:22
Of course it could be a worn spool in the renumerator valve bank, you might want to switch
to extra virgin olive oil.
