Grill for 77 Oliver
Old standard
04-26-2004 13:29:47
Does anyone know where I can find the 2 halves that make up the grill for a 77 oliver?
I have a set
04-28-2004 09:43:11
 Re: Grill for 77 Oliver in reply to Old standard, 04-26-2004 13:29:47
I have a set in the garage. They're in decent shape but with some dents, bends and surface rust. Send me your email and I'll send you some photos.
[email protected]
CCH
04-26-2004 17:00:03
I have a set of grills for a 77. They are not the same as an 88.
Old Standard
04-27-2004 06:43:34
 Re: Re: Grill for 77 Oliver in reply to CCH, 04-26-2004 17:00:03
What kind of shape are they in and do you have pictures of them, and how much do you want for a pair?
Rodney
04-27-2004 10:10:11
 Re: Re: Re: Grill for 77 Oliver in reply to Old Standard, 04-27-2004 06:43:34
Howdy,
Let me look at them tonight now that I have an idea of what to look for and I'll make sure of what I have. Send me your email address.
Rodney
[email protected]
Rodney
04-26-2004 13:37:58
Howdy!
I have three sets of grilles, problem is, I don't know for sure what tractors they fit. They're not in bad shape, some minor dents and dings and some surface rust, but they were stored inside for years. If you can tell me how to tell what I have, I might be able to help you out.
Old Standard
04-26-2004 13:49:17
 Re: Re: Grill for 77 Oliver in reply to Rodney, 04-26-2004 13:37:58
I am not sure how to tell either, I do not know if the 88's were bigger or not. Minor dents and dings and surface rust is NO Problem for me.
Sherry
04-26-2004 17:20:54
 Re: Re: Re: Grill for 77 Oliver in reply to Old Standard, 04-26-2004 13:49:17
The 66 & 77 use the same grill. The 88 & 99 use the same grill. On the smaller grill (for 66 & 77) under the bottom vent or opening, it is smooth all the way down. On the larger grill (for 88 & 99) below the bottom vent, there is a rib or indentation. It's about half way between the bottom of the grill and the first opening. It's very obvious and that makes it easy to tell. If you look at some pictures on the photo page, you'll see what I mean.
A.P.
04-26-2004 17:14:54
The Fleetline 66&77, Super 66&77 and the 660 all have the same grill. The 88 and Super 88 use a larger grill. The 88's have a horizontal step (out)just above the bottom edge at the outside corners. The 66 and 77 grills are flat in this area.
A.P.
