Super 88 Clutch
Nathan
04-24-2004 18:47:47
I have a Super 88 with a stuck clutch-- not just that the clutch is stuck to the flywheel, but the pedal won't go down. I don't think it's just the pedal itself either, because it will move a fraction of an inch, but the linkage is stuck solid. I noticed that on the front of the bell housing there is a small hole that is supposed to have a plate over it; that is missing. Is that probably the cause of my problem, i.e., water has gotten in and rusted everything up? Will I have to pull the engine forward to repair it? Thanks in advance for the help.
Nathan
Jeff
04-24-2004 21:55:23
 Re: Super 88 Clutch in reply to Nathan, 04-24-2004 18:47:47
If you don't have the belt pulley unit on it I would say you don't have to move the engine if you have to go into the clutch. The I T manual recommends it but a clutch can be changed without moving the motor. You'll have to pull he PTO unit out far enough for the shaft to cleear the transmission and other than that just unhook the splined shaft and unbolt he bell housing and mve it back. Now if it has the belt pulley unit or somone has put a Power Booster in there you will have to move the motor I think.
Try the blaster first though and make sure the linkage is good before doing all of that.
cornfused
04-24-2004 18:55:20
Try some blaster or other good penetrating oil and see if you can disconnect the linkage to make sure it is free then try it again.
