Oliver 550 front wheel - urgent
Patrick
04-24-2004 16:06:29
Hi everyone,
I am in the greater Ann Arbor, MI area; about 45 min west of Detroit. I've been working on my lawn with my Oliver 550 and must have overloaded the bucket. My wheel tore right off the spindle, leaving me in a pretty bad state. Thankfully, it was nearly the end of the day. Tractor Supply can't get a wheel and I don't know of a dealer in these parts.
If anyone is within a reasonable distance (2-3 hrs, tops) of Ann Arbor or is near Toledo, Detroit, Grand Rapids, Lansing, Flint, etc and has a good wheel they would part with, I would be eternally grateful.
Feel free to email me at [email protected] or call my cell at 313-304-3999.
Thanks.
Matt K
04-26-2004 12:08:46
 Re: Oliver 550 front wheel - urgent in reply to Patrick, 04-24-2004 16:06:29
Try Pioneer Rim & Wheel. www.pioneerwheel.com
Don-WI
04-25-2004 07:52:42
Did the hub come off the spindle, or did the rim come apart? The reason I ask is because on our massey 285 the hub ripped off the spindle, and we had to replace the spindle because the threads were shot. Bearings aren't that hard, almost any dealer has or can get what you need. All you need to give them is a part #, found right on the bearing and race. Hard part is sometimes getting the race out if it needs to be replaced.
Donovan from Wisconsin
Patrick
04-25-2004 11:07:57
 Re: Re: Oliver 550 front wheel - urgent in reply to Don-WI, 04-25-2004 07:52:42
The rim pulled off the hub. My understanding of the parts on this tractor is that the spindle and the hub are one fixed part. So, might be a different situation.
Don-Wi
04-25-2004 13:29:07
 Re: Re: Re: Oliver 550 front wheel - urgent in reply to Patrick, 04-25-2004 11:07:57
If it's a 6-bolt rim, they are pretty much all a standard 6" bolt circle. the only differences are the offset, width and diameter. As long as it a replacement fits w/out interfering it will work. Someone should have a link to miller tire, or otherwise you should be able to find a rim locally. To your spindle/hub: The spindle is what the hub goes over, riding on 2 taper roller bearings, one bigger one on the inside, and one smaller one on the outside. They are held on with a castle nut w/ a cotter pin going through the nut and spindle.
They are one assembly, but they can be taken apart.
JJS
04-24-2004 19:35:58
Also Card Bros. on M57 in Chesaning a agco/white dealer Ph 989 845-7370
Good Luck
Joe
JJS
04-24-2004 19:25:13
Try Diuble Equipment 4365 Parker Rd. Ann Arbor MI.
Your local Agco/white dealer. They might be able to get you the parts. Joe
cornfused
04-24-2004 17:48:25
Try Maibach? 1-800-808-9934 Creston Ohio.
Patrick
04-24-2004 18:11:05
 Re: Re: Oliver 550 front wheel - urgent in reply to cornfused, 04-24-2004 17:48:25
Thanks for their phone number and the proper spelling of their name. I know they are down the Toledo way. I was kind of hoping someone had a second had front wheel they didn't have use for. On top of wanting the replacement asap, I was hoping for a second hand unit.
Thank you.
cornfused
04-24-2004 18:22:24
 Re: Re: Re: Oliver 550 front wheel - urgent in reply to Patrick, 04-24-2004 18:11:05
Can't help you there but a lot of the older implements and front tractor wheels would interchange. You might try that if you have anything handy.
Darryl Nealis
04-24-2004 18:38:55
 Re: Re: Re: Re: Oliver 550 front wheel - urgent in reply to cornfused, 04-24-2004 18:22:24
I have an Oliver 550 Diesel and have been told that Ford tractor front wheels will interchange with the Oliver 550.
Patrick
04-24-2004 19:50:56
 Re: Re: Re: Re: Re: Oliver 550 front wheel - urgen in reply to Darryl Nealis, 04-24-2004 18:38:55
That is really interesting. TSC had a Massey wheel hanging out and I dismissed it outright. But, if the bolt pattern works, I might be back in business, Thanks!
Also, thanks to the folks with other dealers and phone numbers. All good information.
